Transmission Issues - Help! :(
Hey everyone,
I have a 2007 Audi Q7 4.2 S-Line... Just bought it with engine light on, and worked that out with (2) MAF replacements. Engine appears to be perfect again. I am however, running into issues, directly after replacement of the MAFs, with shifting problems. Is this just strange coincidence? Or can that be linked?
After MAF R&R and clearing codes, I drove it about 6 miles to run 3 errands- shut it off 3 different times. Each time I drove it, the issue got worse and worse to the point of not being sure if it was going to go into gear when 3 point turning it back into my garage.
The problem: It was downshifting into 1st & 2nd VERY abruptly, to the point of your voice jumping while talking. When it would shift into 2nd & even 3rd occasionally, it would also thump pretty hard into gear. By the time I got it home, it would delay shifting from D to R about 5 second, and drop into gear very hard... Kinda like when you park an automatic on a hill without the parking break, then try to drop it in gear. "THUMP". I haven't touched it since.
The kicker, is I just bought this car AS-IS and am screwed. It showed NO behaviors like this, until today. I just drove it home Thursday night and it sat until this morning.
Thoughts??
~George
Thoughts??
~George
Hey mate, have you tried giving the manual shift mode a go by pushing the stick over to ‘s’ Then pushing up or down to see if it will hold the particular gear requested or by also using the paddle shifts on the steering wheels whilst in ‘d’ as this will also overcome the auto shifting and manual push it up or down to the next gear.
once you give this a go it will decide the next path of troubleshooting to follow.
cheers
cheers
Thanks for your reply! I just drove it again after letting it cool all the way down. It acted exactly how it was supposed to after starting it and driving for 4-5 miles. All seemed fine until I got home and let it sit idling outside while waiting for my wife to come out. I thought I’d fixed it after replacing the 2nd MAF (didn’t realize it had two.. DUH). Once she got in, and we drove away to run errands, it started doing all that stuff below again. As you requested, I tried manually shifting it and it did ‘hold each gear’ and upshift and downshift as expected... just very clunky and it seems like it’s very bad for the transmission.
I am inclined to think it is NOT the internals as it’s works beautifully until it gets hot or has been run a bit. If it was bad I’d think it’s just always bad. I’m thinking it’s ancillary but I don’t know??!
-EDIT- I recall romping the throttle a few times before it started really acting up
So very confused!
George
So very confused!
George
Hey mate. Just out of chance with the air flow sensors were the place in the correct way around with the arrows both facing towards the centre of the engine and no chemical spray cleaners used on the insides of your intake tubes? This will really upset the sensors otherwise.
As for the shifting transmissions do have a common link between error and been warm. As the solenoids used for shifting heat up the magnets become weak and cause the valves to stick resulting in driving habits Like you have as you mention on when the car warms up. Also on the other flip side the oil can also contribute to this as well by when it warms up it looses It thickness and begins to aerate due to the oil been old.
audi said these trans were sealed for life with oil. I have a 09 model same as yours and recently changed all my driveline oils at 130,000klm and without a doubt
The trans responded better.
do you have a Audi software tool or only a OBDII tool to check for errors mate?
Update: Pulled fault codes with a neighbor's VagCom. I have a total disaster on my hands here. 13 different fault codes, some appear severe. It seems so bad, that it makes me wonder if it is centralized to an ECM or major electrical monitoring component. It's pretty bad!
Mileage: 192840km-119825miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 1010
34-Level Control -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FQ HW: 09D 927 750 FQ
Component: AL 750 6A 0999
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 02008CB65DFFEA569C-8056
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
17114 - Gear Ratio Monitoring
P0730 - 003 - Incorrect Gear Ratio - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 F
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0021553
Shop #: WSC 00000 000 00000
VCID: 2952FB1A8009D90EFD-807C
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 160
Mileage: 192610 km
Time Indication: 0
Date: 2017.10.29
Time: 10:23:00
Freeze Frame:
Count: 128
Count: 9025
Count: 128
Count: 39168
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 192808 km
Time Indication: 0
Date: 2017.11.11
Time: 11:53:13
Freeze Frame:
Count: 0
Count: 8257
Count: 8193
Count: 50176
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100635235
Coding: 0000135
VCID: 63CEA932A2A5435EF7-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
3 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 3
Reset counter: 124
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 15:36:07
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 157
Mileage: 192404 km
Time Indication: 0
Date: 2017.10.25
Time: 16:57:13
007 - Short to Ground
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 192232 km
Time Indication: 0
Date: 2017.10.21
Time: 00:13:40
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000093132
Coding: 0786472
VCID: 61C2A33AB8B9514EE5-8034
2 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 17
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 13:30:48
Freeze Frame:
Temperature: 25.0°C
02508 - Temperature Sensor for Refrigerant (G454)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:49:26
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06C08804B
Coding: F5F7FE7F347202
Shop #: WSC 91445 999 84053
VCID: 6CDCC20E4F7B0C2646-8038
1 Fault Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 161
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:56:07
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000092665
Coding: 0000006
VCID: 68D4BE1E5B83200622-803C
1 Fault Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:09
Freeze Frame:
ON
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
Shop #: WSC 46668 573 00453
VCID: 2A500416850FD216F4-807E
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 192336 km
Time Indication: 0
Date: 2017.10.22
Time: 12:04:21
Freeze Frame:
Error Code: 78
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 165
Mileage: 192799 km
Time Indication: 0
Date: 2017.11.09
Time: 20:08:34
Freeze Frame:
Error Code: 68
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
VCID: 2F661502BEEDB73E23-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 121
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:38
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 31
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:10:24
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000072907
Shop #: WSC 91445 999 64987
VCID: 64CCAA2EA7AB44660E-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 32100990Q8
Coding: 344630393135313035442056413033323130303939305138
Shop #: WSC 91445 999 06574
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 16:06:07
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
VCID: 3162137AA8D9A1CE35-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 121
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.06
Time: 15:41:25
End-------------------------(Elapsed Time: 03:15)--------------------------
Coding: 0000504
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
Revision: 00H30001
Coding: 0021553
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 160
Mileage: 192610 km
Time Indication: 0
Date: 2017.10.29
Time: 10:23:00
Freeze Frame:
Count: 128
Count: 9025
Count: 128
Count: 39168
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 192808 km
Time Indication: 0
Date: 2017.11.11
Time: 11:53:13
Freeze Frame:
Count: 0
Count: 8257
Count: 8193
Count: 50176
Coding: 0000135
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 124
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 15:36:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 157
Mileage: 192404 km
Time Indication: 0
Date: 2017.10.25
Time: 16:57:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 192232 km
Time Indication: 0
Date: 2017.10.21
Time: 00:13:40
Coding: 0786472
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 13:30:48
Freeze Frame:
Temperature: 25.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:49:26
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 161
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:56:07
Coding: 0000006
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:09
Freeze Frame:
ON
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 192336 km
Time Indication: 0
Date: 2017.10.22
Time: 12:04:21
Freeze Frame:
Error Code: 78
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 165
Mileage: 192799 km
Time Indication: 0
Date: 2017.11.09
Time: 20:08:34
Freeze Frame:
Error Code: 68
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 121
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:38
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 31
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:10:24
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 16:06:07
Coding: 0051722
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 121
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.06
Time: 15:41:25
George,
Did you clear all the codes and try scanning again?
Also, I'd recommend you perform a tranny adaption on the vehicle. BTW, I'm local to you and have some experience with the 4.2 model Audi + have a full VCDS
Transmission Adaption instructions
George,
Do you really think that just clearing all those codes fixes the problem? What would I look to gain from that?
~George
George,
I just read some of that transmission adaptation instruction- My last question was answered when reading that (sorry about that). Looks like the codes need to be cleared to do this. This looks poretty complicated, and, I don't actually have the VDCS, I just had a town neighbor swing by and draw the codes for me then left
Originally Posted by George Trudeau
I apologize for the SPAM Would I be able to perform this adaptation with the Hex+Can on the 17.8 release?
You’re not spamming. You have an issue and the community is here to help you. Just give them a bit to settle in and I bet you can get your diagnosis straightened out.
Best of luck to you,
Grey
