Audi side assist: Sytem Fault Help Needed
My side assist failed a couple weeks back, i scanned today. Can anyone tell me which side the faulty sensor is on? I was told the bumper cover needs removed to access this, so not a winter priority. Still, would like to know which part and side to replace. Thanks!
Code:
Tuesday,13,December,2022,16:27:54:08645 VCDS Version: Release 22.9.0 (x64) Running on Windows 11 x64 www.Ross-Tech.com Address 3C: Lane Change Labels: None Control Module Part Number: 4L0 910 566 B HW: 4L0 907 566 A Component and/or Version: J0769_SWA_MasterH07 0070 Software Coding: 0010001 Work Shop Code: WSC 31414 790 00001 Additional Info: 4L0910568B J0770_SWA_Slave_H06 0070 Additional Info: Geraet 00001 VCID: 2D070725511322337C5-8078 2 Faults Found: 02850 - Control Module 2 for Lane Change Assistance (J770) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 199940 km Time Indication: 0 Date: 2022.11.24 Time: 11:51:09 16365 - Control Module - Electrical Error; CPU 2 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 104 Mileage: 199940 km Time Indication: 0 Date: 2022.11.24 Time: 11:51:10
J770 is the name of the sensor, Googling that lead to this thread. Looks like it is behind the rear bumper cover.
https://www.audiworld.com/forums/q7-...on-4l-2947703/
-Wes- (12-13-2022)
bg_2007Q7 (12-13-2022)
Darn it. Pothole's link sent me down a rabbit hole a bit. However, I came across this TSB for the later 4Ls that applies to an issue I have occasionally, and it has a fairly good shot of where the module(s) are mounted on the shell. I'm not really sure if you could access it without removing the bumper (if that's all you're in there to do), but it's more possible where they're located than pretty much anywhere else under there.
https://static.nhtsa.gov/odi/tsbs/20...68752-6903.pdf
The following 2 users liked this post by -Wes-:
bg_2007Q7 (12-13-2022),
Pothole5000 (12-13-2022)
Ixxe
04-11-2015 11:22 AM
mksap11
VAG-COM Discussion
12-17-2006 02:28 AM
