Battery re-code clarification?
The battery swap procedure while goofy, was nothing challenging. For the recode I used OBDEleven and went into Channel 19 Gateway adaptation 004 and changed the serial number (which had been all 0’s), to the serial number off the new battery’s BEM sticker. I left everything else the same (the “000 915 105 DL VAO”).
Is that the only change required to recode the battery?
Or do I need to go someplace else in OBDEleven to also change value/recode? It seems some older Q7 (or other model Audi’s) have a Battery Management System where they update a value there, but I don’t find this channel (61) on my 2015 Q7.
Don't run the new battery without that, though, because the car won't charge it properly and you'll have additional issues in the near future as a result. Or, just unplug the silly management system until you get it sorted out (though, I'll admit, that's not a popular choice around here, so I won't advocate that for anyone other than myself).
So, I replaced my battery a couple months ago. Yesterday, I try to start the key using the actual and it just clicked and then the cluster and all went blank. Attempted to jump it but couldnt get enough juice to turn over. Go to work, come home to work on it and it starts immediately. Then, this morning same deal as yesterday morning and it wont start and then the clusters all go out. Over the weekend, I lost my keys. I have a spare fob but its beatup pretty good so I only use it for the physical key. Is it most likely a dead battery due to not having it recoded? Or could it be related to using my broken key fob... Or something else! haha[/QUOTE]
If the car started fine later without any external charging, it can't be the battery. I have found, though, that these batteries can take a long time (like two hours or more) to get enough charge to crank the engine when they do get drained.
As far as draining batteries and not coding them, it seems like maybe issues 6-12 months out from when you installed it are likely related to that.
Not sure what year your Q7 is, but you may also have parasitic drain issues from your touch-sensitive door handles. Ultimately, that was the primary issue on mine. There are some really informative threads on this site about that problem.
