Battery re-code clarification?
#11
#12
They should be on in a "standby" type mode all the time, but they only really draw significant power if they are activated based on touch, etc. When they go bad, they are just on all the time, which is a lot more draw. Too much, as we've found.
#13
OK so my 2015 Q7 is doing weirdness with dying since the headlights drained battery few days ago. I also noticed that there is a delay in the unlocking as I approach the car or I've had to use my fob. I've had to jump my battery to start car a few times since but at first it was after it sat all night. Yesterday it wouldn't crank after sitting for less than 2hrs and it'd been driven 100miles, plenty of time for the battery to charge. I bought a new battery but if I have one of those parasitic drains it's just going to kill this battery too right? So how do I locate and or fix that...or disconnect it for now? And where do I have battery recorded once I change it out or do I use a memory saver??
#14
#15
Thanks Wes, great info!
When you stated “…check the stats after you've done that to confirm that they are reset.” where would I look for these and how do I know if they they have been reset? Since I didn’t look before the swap it is harder to see what may or not have changed. What might be a good value to see to verify the recode was accepted? Or conversely what may be a value that indicates the recode was not taken?
#16
This is the part that told me that I *wasn't* good to go on my last battery replacement. I bought an AGM unit from O'Reilly because it was the only game in town. It didn't have a BEM sticker, so I went through all sorts of rigamarole to try and get the right info coded (I didn't). A year later, the battery was dead as a doornail. Thankfully, I was able to get a prorated replacement from O'Reilly, and that time I just unplugged the system rather than deal with the coding stuff. No issues since then. However, I also found out about the door handle thing while I was here asking questions, etc., and I disabled all of those the next summer, so I'm sure that both items have conspired to help this battery have a longer life. I think I'm at about two years on it so far, so I should have several more years to go before having to worry about it again.
iVTEC Yo(ex-B5er)
01-04-2006 01:27 PM
"GTA" B3'88'90Q
04-26-2005 09:17 AM
donp
02-01-1999 09:02 PM
