Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
engine code issue
Old Dec 28, 2015 | 04:05 PM
shmelvin's Avatar
Default engine code issue
I have spent over $600 so far trying to clear this code, they have replaced an oil separator and some sort of sensor and the light keeps coming back on after a couple of hours.
Has anyone else experienced this and can you offer a solution?
P0174
bank 2 system too lean
confirmed
Old Dec 28, 2015 | 05:45 PM
flynavy's Avatar
Default I would find a different dealer
was the sensor replaced an 0x sensor?
Old Dec 28, 2015 | 05:49 PM
shmelvin's Avatar
No they checked out OK
Old Dec 28, 2015 | 06:02 PM
smith2010Q7's Avatar
I assume it is the Fuel Pressure Sensor (G247) that they replace? (did they do the volt test or replace it and waste your money)
When was the last time you replaced your fuel filter? I will do that 1st.
Old Dec 28, 2015 | 06:11 PM
some more troubleshooting on your bank 2 problem. (fuel system if you have not replace your filter in a long time)
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
Old Jan 4, 2016 | 08:31 AM
markray's Avatar
That looks like o2 sensor code to me
V10R8
A4 allroad (B8 Platform) Discussion
Jan 27, 2026 12:52 PM
B490MTL
Q7 MK 1 Discussion
Mar 19, 2016 02:35 PM
Netopr
Q7 MK 1 Discussion
Dec 3, 2015 06:46 PM
keithsan
A4 (B7 Platform) Discussion
9
Mar 28, 2013 09:02 AM
robocik74
2.0T FSI Discussion
Mar 24, 2011 01:44 AM
