Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Old Aug 9, 2016, 09:24 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Lighting Guides
Print Wikipost
How to replace interior bulbs with LEDs...
Old Jan 27, 2012 | 08:27 AM
  #11
muski's Avatar
Hasser --
Unfortunately, I don't have a spec for these bulbs -- there are no markings on the ones I have. I bet if you emailed David at tunerdomes.com he could provide you with this information.
Good luck!
Old Jan 27, 2012 | 12:50 PM
  #12
Hasser's Avatar
Originally Posted by muski
Hasser --
Good luck!
cheers for the original post.
i have now changed all the interior lights for LEDS, except the ones i am asking about.
i have some on order.
i looked at the thunderdomes website and they look the same as i ordered, but could be different spec even though they look the same.
time will tell, but the car looks much better in all white than dull yellow.
Old Feb 18, 2012 | 04:28 PM
  #13
coupegt87's Avatar
Hi Muski,
Great write up, I changed all the light following ur directions except the front, how do get the 2 covers off ? do you have to insert a tool or plastic card to pop it out ??? I tried to slide in towards the front as shown the Audi diagram but it doesn't budge ..... I have all the bulbs and this is driving me crazy... please help, thx in advance
Old Feb 18, 2012 | 05:13 PM
  #14
Hasser's Avatar
Originally Posted by coupegt87
Hi Muski,
i did it using a credit card, just slide it in under the panel and prize it away, it just unclips.
be careful not to let it drop as its in 2 sections, the inner part and then the wider outer section.
oh and definately put something across the seats as said originally, i didnt bother and lo and behold one of the bulbs is lost forever in the black hole under the seats!!
Old Feb 20, 2012 | 06:34 AM
  #15
coupegt87's Avatar
Hi Hasser,
Do u insert the credit card to remove the entire piece or did u do it for the 2 separate as shown in FIG 49 & FIG 50 in Muski's picture ????
Thanks for ur help !!!!
Old Feb 20, 2012 | 09:21 AM
  #16
Hasser's Avatar
Hi Hasser,
i just used the card around the outside (main) piece.
slid it all the way round and the whole thing just popped off. you will need to get your fingers beneath the piece to help pull it down.
just be careful as the inner piece will drop along with it.
it should be easy enough.
Old Feb 21, 2012 | 06:04 AM
  #17
coupegt87's Avatar
Thanks Hasser.... removed the cover and replace the bulbs.... the map light bulb is a biatch to put back !!!!
Old Dec 1, 2012 | 03:56 PM
  #18
weth's Avatar
Thanks muski!! You made the switch easy.
Everything works when ignition is on. However, when ignition is off
2nd row map lights flash once when turned on then stay off. I think they worked before with ignition off
Front map lights flicker when turned on with ignition off.
Glove box flashes once then stay off when opened with ignition off.
Anyone else see this, any suggestions?
Old Dec 22, 2012 | 12:32 PM
  #19
Heck52's Avatar
Thanks for the hints. Using your credit card trick I was able to quickly remove the map light panel on my '08 TT and install LED lights.
Old Dec 22, 2012 | 06:55 PM
  #20
muski's Avatar
I just checked this and found the same behavior. If you close the doors and wait a few minutes the lights do go dim, but as soon as you open the door everything comes back bright. I never tested this with the regular bulbs, so I can't say what the normal behavior is. Funny that I never noticed this before, but I rarely sit in the car with the ignition completely off so it never bothered me.
