P0491 CODE help
P0491 CODE help
Hey all, 2015 Q7, CODE P0491 Secondary Air Injection System, Insufficient flow Bank 1
Anyone else have this issue, and what to look for. Possible air pump, solenoid valve, or Combi valve, or vacuum lines
Thanks
Thanks
Diesel? US? Fixed? If yes to all, thats an emissions component and covered by #dieselgate warranty.
VR6, yeah those SAI's are notorious for going out.. yeh gotta just replace the pump 99% of the time..
P* codes are generic, get it plugged into a real VAG specific code reader to ensure its not a red herring.
https://obdeleven.com/en/
If you cant afford an Audi Tech, then that or a more expensive VCDS is going to be pretty much required for you to work on your own vehicle.
Steviecef
03-17-2004 08:46 AM
