Should my brake warning light be on?
Looks like you probably triggered the 'low' brake pad sensor. You'll be due for a change in the coming say 2k miles. Till then you can look forward to squealing stops!
I don’t have a “light” on yet and no squealing. I’ve read the sensors are iffy sometimes and may not work.
The brakes on the Q7 are super easy to work with. Pull a tire and you can have one of the brake pads off in minutes, to both measure and check if the sensor has been ground into at all.
zakress (07-26-2019)
totally agree
I swapped out my front pads to do a comparison (no difference!) and it took longer to jack up my car and take off the wheel than it took to swap the pads out.
Quick reading failure!
http://youtu.be/Xfnp4wOZ3Pg?t=42
You are getting close but not there yet. If rotors are worn enough to have a lip at the edge, it will come on quicker. Your pads are still adequate for safe stopping. I have run them considerably thinner but keep an eye on them. The inner pad typically wears a bit faster than the outer.
FranklinQ7 (08-04-2019)
The light comes on with thousands of miles of life left in the pads, if it comes on as you pull out of the driveway for a big trip.. dont worry about it and fix em when you get home.
FranklinQ7 (08-05-2019)
Agreed. On our 2011 I disabled the sensors when one wore thru and ran those pads another 5000 miles. Those rotors were on their second set of pads and had a pretty big lip at the edge. That contacts and cuts the sensor early.
