Will 295/40/20 fit on S-Line?
Currently running stock Conti 275/45/20 which are thankfully wearing - so noisy and wash out badly when pushing on. Thre's better pricing on a wide variety of 295/40/20 showing on TireRack.
The question is will they fit the standard 20" S-Line wheel and not rub the car?
Thanks all.
Thanks all.
Hmmm... 2 seperate issues Rubbing and rims.
S-line 5 spoke are 9J, 275 is standard on them. 295 is listed standard for 10J Fuel flap gives pressure for 295x40x20 so does manual but neither specifies rim. I checked my original sales blurb but it was actually incorrect as it gave 295x55x20 as an option showing standard rim... WAAAAAY OUT.
I know the 295x40x20 will clear for rubbing. It is a factory option on the 10J rim
Looks like you are correct to query about it being too wide for 9Js. Shouldnt a tire fitter know this anyway?
I am not sure what you are asking. Many different sizes can fit a wheel. For example, my first SUV ran 235/75/15's on stock 15x7 wheels. After running the super skinny tires I installed a set of 31x11.50x15's (over an inch taller and over 2 inches wider). You obviously cannot put a 20" tire on an 18" wheel. But there are lots of different sizes you can run on the same wheel. Tire Rack & Discount Tire Direct actually give different size choices while still using stock wheels etc. Hope that helps.
BlackS4tt (Josh)
15
03-03-2005 03:52 PM
Scot J
03-18-2004 04:57 PM
LCP
08-23-1999 12:59 PM
