2019 Q7 oil change video ?
Are there any videos out there showing how to change the oil in a 2019 Q7 3.0 6 cyl?. I am not finding any. I am guessing the 17-18 Q7 would be the same? Thank you.
I believe it's 30 Nm or 22 ft-lb.
I found the video generally useful for my first oil change at 4k mi (old school) yesterday, with one bizarre exception. The tech loosens, but does not remove, the drain plug. He then tightens the plug, apparently without bothering to change the crush washer. Gotta say that this is not good practice. Every car (mostly German) on which I've ever changed the oil calls for renewing the crush washer when changing the oil.
Other than that, I noticed that his belly pan was fastened with a combination of phillips and torx screws. My 2019 uses only torx (T25 and T27) for this purpose. Further, the drain plug takes a T40.
Spyder
Spyder
I asked on another thread about using an evacuation device to suck the oil from the top rather than having to get underneath and removing all the screws from the skid plate. I think when my last free one is done, I’m going that route. Any videos for that method?
