Airmatic Lowering Links Error
Anyone install the Airmatic lowering links and get an error? I had my local shop install them and we got a suspension error message that keeps coming back. I have a follow up appointment next week to hopefully resolve but looking for feedback to help them problem solve. The links came with directions and I didn't bring them to the shop (since they have installed many links on other models) but I will bring those next week.
Thanks,
Tony
Thanks,
Tony
Thanks,
Tony
Thanks,
Tony
Thanks,
Tony
Thanks,
Tony
only thing I can think of is maybe the shop didn’t put the air suspension in service mode during the install. And if the suspension tried to make adjustments while the links weren’t connected it could have caused an error. maybe try installing the factory links and see if the dealership can reset the basic settings.
Airmatic guy thinks it might be too low. How many inches are you at fender to ground? I know you were low to start so I doubt that is the reason. I’m at 31” front, 31.25” rear fender to ground
I know they didn’t have the vehicle in off-road/jack mode so I wonder if that is the issue.
Yeah your car is too low! On my S7 anything lowered past 17 mm's will give an error. There may be more room on your Q, but that is definitely your problem. Not sure how Erwheezy is getting away with his ride height, but I would bet if you lifted it up a little the errors would go away.
I have had errors with 3 different setups. I got an error with lowering links when too low, with VCDS when I went too low and finally I got an error with the Cete lowering module. So that leads me to believe when you pass a certain threshold the car senses it and throws up error messages. When I kept all the above lowering methods to no more than 17 mm's (16 S7) I was totally fine and all error's never occurred.
546AWHP/ 626AWTQ 4M.5
Thanks,
Tony
Thanks,
Tony
The following 2 users liked this post by Irvin Fitzgerald:
montgomerie94 (11-04-2021),
ywang98 (11-04-2021)
Irvin Fitzgerald (06-14-2021)
