Annoying Issues
Annoying Issues
I have a 2017 Prestige. You can not turn the radio off. You can turn the volume down or mute it but you cannot turn it off. I can't believe that this does not bother anyone else. When you start it up later the muting is gone and once again you have to turn it down and mute it. The tire light low pressure light comes on for no reason. All tires have the proper inflation and yet I have a low pressure light. Really annoying! Audi should add an on off switch to the radio and correct their tire monitoring issues. Today, almost any luxury car will tell you the tire pressure in each tire and which one has a problem if there is one that is flat. This really needs work! Am I missing something?
As far as radio operation - it is a matter of habit mostly... You can turn radio/media off by pressing small button in the middle of the central lower console section when you don't want to use it. Pressing small wheel-button on the right hand side of the steering wheel controls does the same. When you switch it on again it will be at the same sound volume level it was left before turning it off. As of per my knowledge radios are set this way in all VAG vehicles.
I've had the radio wont turn off issue as well, during recent one year service I had a software update, don't know what it addressed specifically but haven't had the radio issue return as of yet.
Both these topics (radio mute & TPMS) have been discussed extensively here in the forum. You should find sufficient information.
My radio definitely un-mutes every time the car is restarted. On another subject, how about the fact that you cannot lock the car without a key fob? You cannot lock it and then slam the door, or lock it from the outside unless.....you have the key fob......annoying......
Have the dealer look at it. I believe there is a software update that should resolve this.
Why would you want to lock the vehicle without the key fob? You could always use the Audi smartphone app to lock/unlock remotely if thats what you want.
I'll tell you why. We took a boat from Key West to Fort Myers, got there after a very long day to spend the night before driving home in the AM. The battery was dead and wouldn't hold a charge. We we able to drive to the hotel but as soon as I turned it off, there was nothing. No way to lock the doors! We had to have it towed to a safe place at the tow yard in the middle of the night and then towed in the morning to Fort Myers Audi who gave us a new battery under warranty. Not a fun experience.
Just to clarify, TPMS (Tire Pressure Monitoring System) is the term used by all monitoring systems. I believe you are referring to "active" TPMS which uses individual wheel pressure sensors (and is no longer used in most Audi models) vs. "Passive" TPMS which uses the ABS/wheel rotational method to monitor the tire pressures.
