anybody towing an 27 airstream
and? Do you think all those semi trucks are rolling around with empty trailers?
OP: Check out the RedArc Elite brake controller, nice and minimal.. You'll want Air Suspension since you cant hookup a WD Hitch unless you have CanAm modify the hitch.
I do not know Andy and I have no affiliation with CanAm. But we are Airstreamers and have crossed paths several times and I've read a lot of his writings. I have never read of a bad experience from an unhappy customer. YMMV.
Thanks for the info. I am on the airstream forum also and have seen some posts about canal. I'll contract them we I get my car.
Any thoughts on the air suspension ? Some say it a must have for towing.
You dont want your tow vehicle sagging *** for a multitude of reasons, stability being a large part of it (ie, bouncing arround after hitting a bump).. Air Suspension keeps everything nice and level even with 700lbs of tongue weight hanging off the back.. Without Air Suspension the only other good way to level out the TV is with a Weight Distribution hitch, which the manual explicitly says dont do.. the mods CanAm does to the hitch strengthens it so it wont break with a WD hitch, without the mods someone on these forums reported nearly breaking the receiver clean off going over a speed bump slowly w/a WD Hitch.
Plus the air ride when towing is going to be far more comfortable, and you MK2 owners get all wheel steering which would help reversing a large trailer significantly..
these are your options from worst to best:
- Spring Suspension w/no WD, Your *** will sag and your front end will be lifted.. At best you'll look like a tool with more trailer than brains.
- Spring Suspension w/WD Hitch, Requires Modifying the Hitch, You'll be level but connection/disconnection is alot more physical and mental work. (tension bars are not for the meek)
- Air Suspension w/no WD, No Mods needed, no reconfiguring hitch for various loads.. everything is automatic and you can tow anything within spec.
- Air Suspension w/WD Hitch, Requires Modifying the Hitch but with a good Anti-Sway WD Hitch it would be the most stable and should significantly increase your towing capacity.. CanAm was towing huge airstreams with this setup.. IIRC like 9000lb trailers w/shorter wheelbase touareg's
All that said, my 21' Lance travel trailer is ~5500-6000 lbs loaded, but with a heavy tongue. I'm maxed out on the hitch weight, and I have adaptive air suspension. I am running a sway controller (but no WDH). The car tows it amazingly well, even in Utah over pretty significant passes and even with some pretty strong winds. I have not had any "tail wagging the dog" difficulties.
OH, and YES, adaptive air is awesome and I think a "must-have" for towing a big trailer!
