Disable trunk open on key
calculi (06-13-2021)
There is coding that can increase the time required to hold down the fob button to open the rear lid. You would have to get an OBD11 or VCDS etc to do the coding.
Module: 46/Control Module Comfort Sys
Adaptation: Time for opening rear lid with remote control
Old value: 800ms
New value: 2000ms
Vcds - disable boot open with fob
Worked out how to do this on my S3
Connect a VCDS interface to the vehicle.
Select “09-Cent. Elect.” to access the Central Electrical Control Module.
Select “Security Access” and enter code 31347 and click the “Do It!”
Select “Adaptation”, Click on the “Channel” selector drop-down menu then select “(12)-Access control-Direkter Auswurf des Heckdeckels”.
The “Stored Value” should read “active”. Now, select “New Value” selector drop-down menu, and select “not Active”. Select the “Do It!” button.
A window will pop up to confirm the changes you are making, it should state that you are changing the value: FROM: “active” TO: “not active. Click on the “Yes” button to confirm the changes.
What year S3 do you have? I suspect i should be able to do the same thing for our 16 A3 using my laptop loaded with the Ross-Tech VAGCOM program.
Thank you. I have been looking for how to do this. Our A3 has been randomly popping the trunk open, sometimes when tbe ignition is turned off and just randomly while the fob is hanging on the wall.
