DIY Pollen Filter replacement?
Old 04-29-2017, 05:25 AM
Randy Lominick's Avatar
Default DIY Pollen Filter replacement?
Going for the first oil change. The deal wants $115 for the part alone, plus installation time charge. I have always done these DIY but I don't know where the filter is located on this car nor how easy/hard it is to replace? Do you guys know how to replace it? Do you recommend any specific filter as a replacement?
Along the same lines, the dealer also recommended an alignment at 20k miles. I don't see any wear on the tires indicating alignment issue - my thought is that the car shouldn't need it - what do you guys think?
Old 04-29-2017, 07:24 AM
Eppieguy's Avatar
I know there's a cabin air filter which I'm unsure as to where it exactly is, I thought it was accessed through the glove compartment? But a pollen filter I've never heard of.
Old 04-29-2017, 10:03 AM
Default Cabin filter vs pollen filter
Yeah, my mechanic called it "pollen" but I think "cabin" is the more common term. My guess is under glove box access like older model Q7 but when I looked, there is a fragile looking piece of foam that I would rather not remove unless I am reasonably certain that I need to.
Anyone who knows for sure I would appreciate the help!
Old 04-29-2017, 03:57 PM
Mesquite77's Avatar
It is under and behind the glove box, just like on a recent A6 looks like. The foam thing cover is held in place by 3 tabs that you loosen with a screwdriver, then release. if the floor is clean it is not too bad, get your head under the glove box and use a flashlight:
Old 04-29-2017, 04:02 PM
Mesquite77's Avatar
After the foam thing is out, there is a plastic cover you remove, and the pollen filter is behind that. DIY about $20 with compatible filter.
Old 04-29-2017, 04:17 PM
Awesome! Thank you - now I just need to buy a filter that will fit. Do you know of a place to buy one that will fit or get OEM for a reasonable price (dealer wanted over $100 for the part).
this site says that their filter works but lists years from 2011 - 2017 so that makes me wonder if their info is correct.
http://www.autopartswarehouse.com/sk...ASAFC1342.html
Thanks!
Old 04-30-2017, 05:14 AM
Mesquite77's Avatar
The Audi part no is: 4M0819439A and the 4M is the key to indicate Gen2 Q7.
Cairid website seems to think the Hastings will fit, only $17, worth a try. The genuine Audi part runs about $32, get one of each and you'll be set for a while.
On my A6 same price difference with Hengst filter looking identical to OEM, 1/2 price, made in germany.
Old 04-30-2017, 05:34 AM
Default Thank you mesquite77!
Great info! Thanks so much!
Old 04-27-2018, 10:26 PM
soguy12's Avatar
Hello Mesquite, You seem like an expert,
Do you know how to replace the engine Air filter? for 2.0 Q7 2018
And do you regularly change your oil for your 2.0 Q7?
I feel the car runs worlds smoother when oil is changed,
I plan on changing oil every 5000km
either at independent shop or maybe DIY
Old 04-27-2018, 11:49 PM
Mesquite77's Avatar
Check this thread here, the air filter box cover comes off easy, 2 clips at front, careful not to lose them, getting to the oil filter takes extra steps:
https://www.audiworld.com/forums/q7-...ation-2940593/
Also, there is a long thread here "DIY Oil Change".
trlyka
A4 (B7 Platform) Discussion
08-10-2009 07:48 AM
quickaudi:STFA
06-03-2006 07:20 PM
Seanism (clone510)
08-13-2004 05:05 PM
jgonzo911
09-03-2002 05:20 PM
beep-beep
Audi 100 / A6 (C4 Platform)
9
06-28-2001 06:27 AM
Quick Reply: DIY Pollen Filter replacement?
