Oil not full after oil change?
Second oil change with a new Audi dealer since we moved. Both times the vehicle menu for oil level shows less than full a day or two after oil change. First oil change it showed 80% full and the most recent time it was only 70% full.
Dealership is very good to top it off but I don't understand why it wouldn't be full? I'll ask them when I take it in but wondered if others have the same experience?
Yes, engine was fully warmed up and I followed steps outlined in the manual.
Oil consumption with 67,000 miles averages one quart every 4-5,000 miles. It's been steady since I bought the car new.
The following 2 users liked this post by a75:
CrazyEights (06-14-2023),
uberwgn (06-12-2023)
I'm not thinking my Q7 has burned that much oil in a couple days. What I'm thinking is my Q7 left the dealership with less than a 100% oil level. They did not put in enough oil to begin with.
a75, are you saying it's ok for a dealership to only fill the oil level to 70 or 80%? "This does not mean that the engine oil level is 70% or 80%. These are just the minimum and maximum allowable levels. It is worth reading the manual for the car."
I regret how confusing my original post appears to be.
Proxs, that bar graph does NOT represent the entire oil capacity. It's typically just a quart/liter of oil. When the bar graph is at the bottom, it does NOT indicate the vehicle is just about out of oil.
I would leave things alone and check the level every week or so if you are concerned about oil consumption. Just monitor it.
It takes a few days and some driving for the oil level to be accurate following an oil change.
