Q7 Tiptronic 2018 - Jerking Issue & Changing to Neutral mode while running
Hi All,
Last year I owned a new Audi Q7 Tiptronic 2018 Model. I have few issues since I bought the car.
1. Jerking/vibrating after Auto start
2. The car is going to Neutral mode if we are not accelerating while running. If we touch the accelerator, the gear number will show in the meter. Is this a common problem?
The Audi technician informed that both are normal for Audi Q7 models
Cheers
Anish
Cheers
Anish
Hi All,
Cheers
Anish
Cheers
Anish
Take the SA rep for a short ride and give him a coffee mug with hot coffee from the waiting room to hold as you do so and try and recreate the problem. If it happens on the test drive, ask him if it's normal.
Hi All,
Cheers
Anish
Cheers
Anish
2. I'm not clear what exactly you mean. So you are coasting along with your foot on the gas pedal, and the transmission slips into neutral? Then when you accelerate, the transmission slips into gear (which one?)? Why do numbers show in the meter? Can you record this issue and post it here?
Hi All,
Cheers
Anish
Cheers
Anish
We don't see gear number in US version. It only shows D or S when the car is running.
1. what do you mean? Do you feel the engine starting up, or is it some violent shaking? If you feel the engine starting up and a slight rumble, thats normal
2. Attached video of the transmission. You can see that the car is running at Gear 5 and I am not touching the accelerator pedal, at some point of time the gear number disappeared from the meter and running on neutral mode. If we touch the brake or accelerator suddenly the number will appear.
