So it seems that the Q7 mk2 will be much easier to shop for aftermarket wheels for :)
since it's pretty much jumped on the same wagon as almost all other Audi models in using the 5x112 bolt pattern with 66.6 centerbore.
This is at least according wheel-size.com's info, which I've found to be mostly reliable in the past.
If this is really the case, then this is awesome news!
I currently have an SQ5 I'm planing on trading in for a new Q7 and from the data that I have, it looks like the 21" wheel for the SQ5 have the same exact specs as the 21" wheel of the mk2 Q7. 5x112, 66.6cb, 9x21" with a +31mm offset. Which suggests that assuming there is adequate brake caliper clearance with a particular wheel design, most wheels that fit on the SQ5 should also be a perfect fit for the mk2 Q7... making our aftermarket wheel options that much larger compared to the mk1 Q7's limited options.
In fact, I use the same 20" winter wheels (albeit with different size tires) on both our SQ5 and RS7, so there's probably a good chance whatever fits my RS7 will also fit the mk2 Q7.
This is also good news for those who want just affordable replica wheel options to use as winter wheels, like Hartmanns and others. Most of those wheels are 5x112 66.6 so that gives mk2 Q7's a ton of options to choose from.
