Answers for 83quattroCT (Long!)
Mark; I just finished rebuilding my WX motor and sorting out various issues. Took me almost a year!
I had the motor honed, installed new rings, new bearings, all new gaskets, replaced the WU regulator, and the aux air valve. I replaced the clutch, slave cylider and had the flywheel resurfaced.
Pulled the struts out and put them all on full stiff. Last year I had all the suspension pieces sandlasted and painted Imron black, and had all bushings/bearings replaced. Also did the G60 upgrade with a Tilton manual proportioning valve.
This year I replaced the front tie rods with a good set of used ones.
I went through my steering rack and replaced all o-rings, seals and crush washers. Also, I had all hydraulic hoses replaced, high pressure and return. I did some detailing of small parts while it was all apart. I put all new bonded rubber mounts wherever they are used, like the two radiators.
This is all on top of the watercooled turbo upgrade I did when I first got the car!
Thats all I can think of for now. I'm sure thers more! But..I consider myself about 2/3rds finished. I still have to do the hard stuff, like interior and body work. Fortunately, there is virtually no rust on my car.
Hope this was good readin!!
gmbchef - your car is looking good
and sounds great too. Plus 100% success rate with hot starts! I am sure you are tickled after all that hard work and time. BTW thanks for the steering arm.
Folks, I can vouch that our esteemed executive chef actually has a running Urq
TighTT
Audi Original "S" Cars
19
10-18-2008 06:09 PM
goohead
10-11-2008 05:19 PM
TUnit20V
07-15-2007 06:03 AM
