pistons
pistons
Does anyone know of anyplace that stocks the 2nd overbore piston for an MC engine. I am planning on doing an upgrade to my urquattro, already bought the motor/rods/bearings/etc. and now the machine shop tells me that the pistons are no good. Any help would be greatly appreciated.
Re: pistons
Did the shop give you specific measurements? When I had mine measured, i went through the specs with him. The pistons and cylinders were worn, but still within spec.
HTH
HTH
I have heard that worn bores is a problem on high mileage MCs.
Apparently they end up with a lot of taper, requiring boring and new pistons and rings. This work is not cheap by any means. The correct Mahle pistons are ~$100+/each as I recall. Factor in bearings (AAN for durability), machine work, etc. and you can hit $2k on the bottom end.
Re: I have heard that worn bores is a problem on high mileage MCs.
When I had my 3B rebuilt (the engine had 250K miles) it needed a re-bore but I couldn't find
over sized pistons. I ended up using the
original pistons and having liners installed
in the original block. You wouldn't know that
they are there when you look at the top of the
block. You might want to ask your machine shop
if they do this?
Cheers, Mike
if they do this?
Cheers, Mike
5000Q86
08-19-2009 08:46 PM
OldManTan
Mid Atlantic Discussion
04-13-2006 05:15 PM
Rob5K
12-22-2004 11:17 AM
yourk
11
08-31-2003 07:22 AM
