UR 10V Quattro Clutch Master replace
Hi everyone, my 1986 Audi UR Quattro 10V Clutch Master Cyl. which was resleeved recently has failed again causing Pedal to floor and drags/drives a little in Neutral. I was told the Clutch Master is behind Glove compartment and would like to know if possible how difficult this would be to replace with a new part and is there a complex procedure to bleed the Hydraulic system as I have never bled a Hydraulic Clutch before and am therefore a novice in this area. Any input would be welcome.
as I cannot edit my faulty Thread I will try this method. The Car does not drive in Neutral as I stated (sorry for the mistake) but does drive in Gear with Clutch Pedal fully depressed, so to solve half of the puzzle I have been told this can occur due to air in Brake Hydraulic system which shows up first at Clutch Pedal (all connected) and it is a normal procedure to bleed system so that will be my next step.
boxx
05-10-2006 11:20 AM
