Brake (Dummy) light beeps 3x at every Right-hand turn
#11
OK I see. Actually, I am not clear on the following: I understood that you had 3 separate issues when you posted first:
1. Brake light illuminating on turns
2. ABS and traction control light
3. CEL
Is this correct?
And then #1 was caused by low brake fluid and it is now fixed, is this correct?
3. CEL
Is this correct?
#12
3. CEL
Is this correct?
3. CEL
Is this correct?
A Common trigger for these lights to kick on is say i start up in the morning, (sometimes it's still on from the day before, sometimes not) and I drive to work. I sit in parking lot and chill for a bit before I walk into work. After a minute of idle-time the both lights come on. Or if I approach a stop light that is for an extended period of time, they turn on also. Today I parked the car at work, they turned on and when I came out after work, they were not on. They did not get triggered my whole ride home. It's so spurratic.
#13
Ok good to hear that!
The ABS/Traction control light is a weird one, especially since it is sporadic and inconsistent. I hate these ones as you cannot test that they are fixed right away...
I think there are companies that rebuild ABS modules, I have not used any to recommend though.
FYI, you can order from Audi tradition from the USA here are the details of how one guy did it:
https://www.rs6.com/showthread.php/3...ition-(Germany)
Jack_Tauson_Sr
A4 (B8 Platform) Discussion
12-12-2023 01:05 PM
Turbo Addict
Q7 MK 1 Discussion
08-19-2022 05:24 PM
RydeOdie
11-25-2008 08:11 AM
Eric - The Red S4
06-14-2007 08:38 PM
