So the winner of the "how long will Bobski's DRC hold up after being replaced three weeks ago" is...
120 miles. yes, my car is back in getting a whole new DRC. The DRC failed, then I brought it in for repressurization or whatever BS they think they can do and it failed in 120 miles. I insisted they install a whole new system which they are doing. Should be done Monday or Tuesday.
Am I wrong or is the weak link in the system the shock absorbers?
I have had probably a dozen shocks leak on my car, which in turn leads to the pressure decreasing in the lines and the central valve cylinders having to be replaced. I'm on my third set of valves.
They need another company to manufacture a shock for this system. Why keep sending the same **** to the technicians? (unless they bought 5000 of them five years ago and they are hoping that the cars fade away before their supply runs out)
THAT is the part I find reprehensible about this whole cluster-#%&!.
Yes every leak was at the seal by the check valve connection. Steel fitting, aluminum washer. This
forms a dielectric which results in current flow from dissimilar metals. Then corrosion results.
Mike
Basic mechanics of materials.
Mike
RS4-2007
RS4 (B7 Platform) Discussion
12
12-11-2012 04:38 PM
AMorris
18
12-31-2005 02:07 AM
tragopan86
07-19-2003 04:37 AM
