RS 6 Discussion (C5) Discussion forum for the Audi RS 6 C5 platform
transmission error code
Old Apr 7, 2008 | 01:58 PM
Dr.Aronis's Avatar
Default transmission error code
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4D1 907 558 D
Component and/or Version: 4.2l V8/5VT G 0003
Software Coding: 0006752
Work Shop Code: WSC 02195
2 Faults Found:
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - Intermittent
19497 - Powertrain Databus Implausible Engine Temp. Message from Inst. Panel
P3041 - 004 - No Signal/Communication - Intermittent
any thoughts?
thanks
Mike
Old Apr 7, 2008 | 02:06 PM
16 Wins's Avatar
check for Rats...NOW!!!!!!!!!!!!!!
Old Apr 7, 2008 | 02:08 PM
maxcpa's Avatar
..and snakes
Old Apr 7, 2008 | 03:12 PM
Dr.Aronis's Avatar
Default That's the first thing I did before resetting the Codes....no vermin found...
No Monkey's either....go figure...
On VW site this code is linked to Temp sensor and sounds like a minor fix, but on the RS6 it could be a sensor so far up under there that you need a Rat and a Snake to change it....or an engine pull by several Monkey's..
Mike
Old Apr 7, 2008 | 04:22 PM
Hy Octane's Avatar
Default Re: transmission error code
The evap cannister is a small round thing in front of the passenger side engine bay that makes a clicking sound while driving..Its responsible for recycling the fuel vapors from the tank to the motor.. its an emissions thing.
Second one might be a thermostat going out..
Not sure there..
Old Apr 7, 2008 | 06:00 PM
Dr.Aronis's Avatar
Default Yes, the first one is usually just a loose fuel cap (or dirty seal) the other is more concerning to
but from what I have found appears to be perhaps as simple as thermostat...
Thanks,
Mike
Old Apr 8, 2008 | 05:30 PM
néné's Avatar
Member
Coolant Temperature Sensor needs to be replaced
Old Apr 9, 2008 | 06:30 AM
ip4me's Avatar
New Member
Default ...and dogs!
<ul><li><a href="http://www.fordmuscle.com/blog/whatcha-got-under-the-hood/112260">Crazy Dog</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
jlbell
12
Apr 7, 2016 08:58 PM
PaulW
24
Mar 11, 2014 05:18 AM
PaulW
13
Jan 5, 2014 07:19 AM
gckwang
Oct 24, 2006 02:10 AM
Crazy Ivanski
Feb 27, 2001 08:27 PM
