10mm Spacer? MTM sell 20mm for RS4?
So I've read through this forum and it seems 10mm spacer is the size of choice with stock wheels and MTM are the way to go. When I go to their site, they are touting 20mm for the RS4. What gives and where are you getting your 10mm's from?
Also, any tire wear or suspension tweaks required with the slightly wider track?
Cheers,
Mark
Cheers,
Mark
Here are the facts:
[QUOTE=The Brit;23751671]So I've read through this forum and it seems 10mm spacer is the size of choice with stock wheels and MTM are the way to go. When I go to their site, they are touting 20mm for the RS4. What gives and where are you getting your 10mm's from?
Cheers,
Mark[/QUOTE]
The correct size is 10mm, and MTM makes a perfectly fitted 10mm spacer the RS4 wheels. The inner bevel on the stock RS4 wheel is matched perfectly by the bevel on the spacer. Not all spacers have this design feature. Looks great. No rubbing whatsoever with stock suspension and tires. No hint of any vibration or odd sensations.
Cheers,
Mark[/QUOTE]
