Alignment with Coilovers - what specs?
Those of you who have replaced your DRC with coilovers, what alignment specs have you been using?
TIA
TIA
Here's what STaSIS recommends fwiw. =>
I have Ohlins SL using the Aggressive Street Setup alignment.
<This is copy/paste from STaSIS site>
Conservative Street Setup
Between 1/16 and 1/32 TOE IN front and 1/32 TOE IN rear
Ride height at 25.875" front and 26.000" rear
(-1.0 camber front)
Between 1/32 and 0 TOE IN on all four corners
Ride height at 25.500" front and 25.625" rear
(-1.5 to -1.75 camber front)
Track Setup
Between 0 and 1/16 TOE OUT on all four corners
Ride height at 25.000" front and 25.250" rear
(-2.0 to -3.0 camber front)
WARNING! The Track Setup alignment recommendations are not for the street and will result in serious straight line instability. STaSIS accepts no responsibility with its alignment suggestions.<ul><li><a href="http://www.stasisengineering.com/faq.aspx">STaSIS</a></li></ul>
(-1.0 camber front)
Track Setup
pleasure.
sez '0' to +...close enuff.
Straniero
RS4 (B7 Platform) Discussion
07-11-2007 12:48 PM
wagongotya
04-06-2006 10:16 PM
oldyellar
15
04-13-2005 08:05 AM
HIS4
10
09-15-2003 05:32 PM
