Anyone tried 100oct gas on RS4 ?
yeah I reluctantly had to put in 100 octane at this past weekend's DE event...
reluctantly because it was $7 a gallon and it was long drive out of the track for decent 93 octane gas.
Honestly, it didn't feel any different. Car didn't feel any faster and in the session I went out with the car, it didn't go any faster on the straights before the braking zone. I hit about 115 mph on the front straight in previous runs on 93 octane and it was about the same with 100 octane. Even my lap times were same.
ah I see.....in CA we got crap 91 pee water, I used to mix 100 to bring oct
to around 94 oct on my other cars and was quite a different on feeling, I guess i will do the same then.........
I think so, can advance the timing and mixture, just not sure how much it will yield though....
if someone can come up something like a map switch for RS4, it will be perfect =P
You will probably not see much improvement in performance, what you will see...
is less knock (if your logging) and better A/F ratios becasue the ecu will correct a small ammount (up to about 96 octane the ECU will do corrections). This will allow the car to run at its peak performance and not have any hiccups while doing it. Our standard pump gas is not as good as whats found in certain european countries, race fuel (GT100) is made using a different process then standard 91 or 93 so I would believe you will see like under correction by the engine for "bad gas" as it where. I know the S4 used to love race fuel, plus you have to remember it smells-so-good.
I mixed 5.5gal 100oct with 10 gal 91 oct it brings to 94ish? if ecu will adjust for 96 should I mix
the ratio to 96oct?
I got this 100oct from 76 gas station.
I ran pure 100 on 540, STI and CLK500 before, it was fine but like you said 540 and clk500 gets least difference on performance.
i guess what I am trying to say is....
the ECU adjusts from around 91 to over 94, since 94 octane gas in the US is less then optimal, pure race gas will far exceed 94 in every shape and form and your ECU will adjust a little over 94 but the bigger thing is that the car will not exceed the limits of the gas (something that can happen in 91, 93 or 94. Thats what I am trying to say.
Mark.core
07-25-2003 09:24 AM
the reverend maynard
01-31-2002 11:51 AM
BeNogaro
18
12-18-2001 07:35 PM
GeoS4V8
10-19-2001 07:53 AM
