brakes start to grumble after track day
Rotors has dark spots which don't seem to worn away (normal daily drivin a week now after track day). I have rs6 pagid pads. What to do?
...pads got hot eh...
Try the following...
Use acetone or denatured alcohol on a clean shop towel to remove remaining brake "glaze". It is not recommended to use an aerosol brake cleaner as some feel that residue can promote brake pad glazing.
If this fails, the glaze does't wear off from normal use and you are concerned about noise, vibration, or less than perfect braking (grip-slip-grip-slip) your options are (in no specific order): media blast rotor, rehone rotor, replace rotor.
The binder materiel got too hot, 'flowed' a bit, transferred to the rotor...it will wear off..
eventually after several applications. Easy fast way to get it off...coupla bedding procedures to put heat in them again, but stay off the pedal until the system cools.
thank you very much, check or cash for the diagnosis. :P
bpp
04-21-2008 02:36 PM
jibberjive
11
03-12-2008 04:26 PM
MaD MaTTer
15
01-04-2008 04:23 AM
OneTurboSomeDay
Motorsport Discussion
06-28-2001 01:15 PM
