Check Engine Light stays on
what the hell. bringing it into the dealer on monday. I dont want to drive it or anything. Ill keep you updated. Dealership says its ok as long as it doesnt blink.
Re: Check Engine Light stays on
Mine went on a few months ago. O2 and catalytic converter abnormalities. They told me that if I didn't notice anything, It was safe to drive. They cleared the codes and it hasn't happened since. Hope this was helpful.
Probably not a huge deal.....
First, check for loose gas cap.
If not that, most likely a bad O2 sensor.
If not that could be a throttle plate problem of MAF sensor problem.
Really....all are easy fixes. And I'm 99% sure your car is safe to drive without risk of engine damage. Just don't go nuts.
Of course, now that I've said this, tomorrow is the day you'll be at a light with a kid in a punked out Civic.
Recently had the same thing...
turned out to be a malfunctioning fuel pressure sensor... replaced under warranty, and heard that many audis are suffering from the same issue due to a bad batch manufactured, trickling down to many a4s... they said that most dealers are aware of the issue and thus have surplus stock.
Vijay, you really have no information to make that determination
It may very well be a trivial issue. It may also be serious. There are literally a thousand different things that can cause a CEL to occur.
Step 1 - VAG it or take it to the dealer and determine the code that caused the CEL.
Step 2 - determine what the probable cause of the code is.
Until this happens, we are all self-diagnosing the problem.
