Does this look like DRC failure?
When I replaced the stock brake pads with the low-dust centric posi-quiet pads, I took some pics. Just under 19K miles when I did this. When I got the 15K service done, I asked the dealer to inspect the DRC and they said it was ok at that time. This looks like the DRC is leaking, wondered if anyone else agreed.
First pic is the driver side, second pic is the passenger side.
Thanks.
Thanks.
It does look cracked/split there, but it is some sort of adhesive label or something that is covered in the gunk, and then partially came off. You can kind of see that label in the second pic, but the leak has not reached it.
Good idea, I will ask them to do the pressure test. I'm at 20K now and plan to take it for an oil change, so I'll do it then. I'll report back. Thanks.
Yes, you have DRC failure. I always said that when my system goes, and it just did after 2 years and 4 months and 15,000 miles that I would upgrade to Stasis. MS are on order now!!!! I am leaking on my right front shock. Looks the same as yours.
Have the same happening to both of my front shocks. Took it to the dealer, they took pictures and said that they will be contacting Audi and ordering replacements. They also said that there is a campaign for the S6 on DRC failures but not on the RS4s. Go figure.
