:: ECS Tuning B7 LED License Plate Light Assemblies!!
Audiworld Basic Sponsor
Back in stock!!
Upgrade your lights and lenses with Ziza LED license plate assemblies. If you're after the bright white look of LEDs, you might as well install your new bulbs in fresh assemblies with clear lenses.
Installation is child's play. The tip in assemblies are a stock installation, held in place with a tabbed hinge and single screw. You don't even have to plug in an electrical connector!
Balanced to load the circuit just like the originals, your new LEDs will light the night, not your bulb alert.
Click HERE to order or for more information.
Let me know if you have any questions.
Jason
Jason
Back in stock!!
Jason
Jason
AudiWorld Expert
I tried these new ones - as well as all the older releases that always threw a code. These new ones work. They initially sometimes throw the code but it goes out after a second. The look is great.
I placed these lights on my RS4 and they threw a code initially. Called ECS and they gave me the fix over the phone. You need to pull the connectors apart a bit farther and that changes the resistance. No more code errors and they look nice.
With all due respect to the forum's sponsors, fixing the problem by purposely loosening an electrical connector doesn't sound right. There must be more to it?
I'm assuming he means the tabs on the backs of the lights. This is the first I am hearing of this "fix". I'm currently trying to figure out who told them this.
Any more information would be helpful.
Jason
Jason
I hope that helps clear it up a bit.
