RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
EPC light came on last night and car has a hesitation now..... (updated)
Old Feb 23, 2009 | 08:56 AM
  #11
BluDemon's Avatar
Guest
Default The service advisor is going to have a flap motor ordered for my Friday appointment.
It could be something else but at least they will have the motor on the shelf.
Old Feb 23, 2009 | 09:09 AM
  #12
silverRS4's Avatar
Default Do they really call it a "motor"
The RS4 manifold flaps are actuated by a 2 vacuum diaphrams - one for each bank. The flaps in the 4.2FSI Q7 are actuated electrically (via solenoid I'm assuming). I don't see how the term motor applies to either.
Old Feb 23, 2009 | 10:01 AM
  #13
bobby26's Avatar
Default had mine on about a month . dealer told me is was the after
marke K-40 that was installed. so they re-wire the whole thing and the lite came on again.
Old Feb 23, 2009 | 10:12 AM
  #14
wankeldude's Avatar
Yes, the are called motors.
  #15
wankeldude's Avatar
Make sure they check the TSB about the cracked/leaky Vacuum line too
Old Feb 23, 2009 | 10:34 AM
  #16
BluDemon's Avatar
Guest
Do you happen to have the TSB number.
Old Feb 23, 2009 | 10:53 AM
  #17
wankeldude's Avatar
Default I think this is the one:
Condition
MIL on with DTC P2015 and/or P2020 in the ECM memory.
24 06 01 Sept. 22, 2006, 2012844
Model(s)
Year
Eng. Code
Trans. Code
VIN Range
RS 4
2006-7
BNS
All
All
Technical Background
Possible cause is a vacuum leak at the vacuum supply hose fitting for the Intake Manifold Runner Control (IMRC) valve N316. The vacuum supply hose fitting is located underneath the center of the intake manifold.
Old Feb 23, 2009 | 10:56 AM
  #18
Jenner's Avatar
Default 2012844/1
<ul><li><a href="http://www.jlosee.com/images/RS4/PDF/TSB-RS4%20Manifold-2.pdf">http://www.jlosee.com/images/RS4/PDF/TSB-RS4%20Manifold-2.pdf</a</li></ul>
Old Feb 24, 2009 | 04:21 AM
  #19
Jet Jockey/A4 Pilot's Avatar
I'd like to try one of those one day!
Old Feb 27, 2009 | 02:34 PM
  #20
BluDemon's Avatar
Guest
Update........above... ^ ^ ^ ^
