Help please - need VAG-COM Coding for Control Module 76 (Parking Aid)
Trying to turn off the Reverse confirmation beep in Control Module 76. My car has 0000304, seems like it should be 0000504. Changes won't stick.
Tried to change adaptation 10 channel 05 to "0" but changes won't stick either.
What is your Coding for 76?
Try recoding the module instead of using adaptation
0000504 should be the correct code. Instead of adapting a channel, try recoding the module with 0000504. It's possible that it won;t accept a zero value at channel 5 because the module is currently coded with the buzzer on. Just guessing though.
I'm sure you have seen RossTech's wiki but just in case:<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Parking_Aid_%284/8-Channel_-_8EC/8ED%29">Ross Tech wiki on parking aid</a></li></ul>
Still need coding for Control Module 76 please, also adaptation channel 05.
Mine are not what Ross-Tech says they should be and it would be a big help if someone with an RS4 could tell me what their coding is.
TIA
TIA
allroad55
Audi allroad
11-03-2010 12:46 AM
drwombat
05-25-2005 10:04 PM
