New replacement rotors from Brembo!
Former Vendor
Brembo now offers a 380x34mm replacement disc option for all RS4 owners. This is an upgrade over the stock 365x34mm factory rotor.
The kit includes the disc assemblies, pre-assembled, brackets to move out the caliper and hardware.
Some of the main benefits of this setup over stock are:
• Larger surface area aids in dissipation of heat
• Slotted discs available for track biased use
• Disc material has high carbon cast iron construction to increase thermal capacity and offer better friction properties
• Curved vane venting that offers better cooling than stock discs
• Thicker disc wall allowing disc to act as more efficient heat sink
• Option to replace just the outer rotor ring while reusing the aluminum hat
Retail $2195, give us a call or email for current pricing!
AudiWorld Expert
Wow impressive
One question - will they allow 18" rims to fit?
and maybe one more question - does this fix the problem with running the F1 track in Singapore??? OK poor joke
Former Vendor
18" wheel clearance is unlikely, but the stock 19's work fine.
These aren't Carbon discs, so no Singapore F1 problems here! Mark Webber, is that you?
AudiWorld Expert
I was wondering if you would get it?
Wow - if I was a more aggressive driver I would get these now. Hell I will get them when my rotors need replacing and warranty does not cover them.
Thanks for offering them
Former Vendor
We carry replacement pads from Carbotech in a variety of different compounds from street to the track.
Obviously OEM pads are another option as well and will work fine.
