Stern Control Arms
Stern Control Arms
<center><img src="http://pictureposter.audiworld.com/70487/stern_control_arms.jpg"></center><p>
Has anyone put this on their car? If so, what are your thoughts criticisms?
Many thanks in advance!
Pretty much, here's the deal
Adjustable camber, which is really only needed for the track. But if you do, you don't want a rubber bushing. You should upgrade to a poly or metal.
Poly or metal will make noise which is not tolerable for most on the street. So these with the rubber bushing are a compromise that should be quiet on the street, but allow you to add camber. But why do you need more camber on the street? And if you lowered, you already added more camber....
You could use these to get your camber back to more original spec if you are lowered too far.
Also, these units do have interchangeable bushings, but I don't think they released the metal/poly yet.
trackonly
12
09-11-2006 07:28 PM
Those with new CPP upper A-arms (rubber boots)..how they holding up sounding?..need either order a..
M3KILR
02-23-2006 08:59 AM
