Is there any way to get the euro Sport Suspesion Plus coil overs?
I asked this a while back..
and someone claimed that it was near impossible and that for the same or less money better COs could be had here anyway.
Take that with some salt, I don't know the real answer.
There's always room for "improvement"...
<a href="http://www.esetuning.com/ProductDetails.asp?ProductCode=KW%2DCOILOVER%2DAUD I&Click=1404"><img src="http://www.esetuning.com/forums/rs4_front.jpg"></a>
Not a fair comparison really
Our STaSIS/Ohlins Motorsport level dampers are really in a different league than the KW V3's. Our dampers are not only rebound and compression adjustable but we also give you a seperate "high speed compression" adjuster to tailor the ride and handling of your RS4. Our dampers also run significantly different spring rates than the KW kit, they run Front=830 / Rear=470 according to their site. We run 800lb front and 1300lb rear to dial out any and all understeer. The aluminum bodied Ohlins (KW is made of heavy steel) are so advanced and react so quickly, to the smallest road inputs, that they are able to control any unwanted suspension movement.
<img src="http://pictureposter.audiworld.com/82232/damper_cutaway.jpg">
This allows high spring rates to be used without harsh ride quality. What this means is that you get the best of both worlds: unmatched track performance WITH OEM ride comfort. It really is the nicest, best overall suspension I have ever driven.
<img src="http://pictureposter.audiworld.com/82232/ohlins.jpg">
We have the kits in stock and we will offer a special price for RS4 owners, call for details.
707-935-9700 ex 119
707-935-9700 ex 119
Does it come withe the cool little badge thingy?
Because if so I am sold
Seriously though. Is this suspension kit specific to RS4 or just works well with it. Is it on the RS4 you guys have at Stassis?
Also, what does something like this do to your warrant?
