Been gone for a while
Hello to you too...
Love your RS4 Grille so much, I just bought one too...
Question, if you don't mind.
How have you secured your S4 Grille badge to the mesh of the RS4 grille?
Thanks in advance for any helpful hints.
butcher the stock grille...(edit)
get a clean mounting surface on the badge and use the 2 part plastic epoxy from the depot. havent tried to do it(like it clean), doesnt seem like a crazy task. what are the problems you guys are running into?
....just looked at my stock grille. and if i were to do it. i would remove the logo as close to the top as possible and remove a 1/4"+/- tab from the filler plate back panel so i would have a piece to adhere to the hex pattern on the RS4 grille. If you wanted to make it perfect you could melt the tab and logo together. and then adhere it. or just use the epoxy.
hmmm...maybe i'll try it?????
