Few questions after a week with the new car...
So I've had the car 9 days now, and I've already got 750 miles on it. So far, I'm having a blast with it. Few things I've noticed that I wanted to ask about...
1. The shift gate. There is virtually no self-cantering action of my shifter when in the neutral position. For example, upshifting 2-3 requires a specific push of the lever to the right, rather than up into neutral, self-centering, and then straight up into 3rd. The alignment of 3rd & 4th also seems to be off. Several times when downshifting 4-3, I've pushed the lever straight up but was not able to get it to slot into 3rd, and then had to play it side to side to find 3rd. Is this a known issue, or do I have a bad gearbox? Anybody know?
2. I have my V1 plugged into the cigar lighter (it will get hardwired soon, I hope). The other day I unplugged so I could use the lighter for a cigar, but it doesn't work. Has anybody had their lighter burn out, short out, or whatever, from having the radar detector plugged into it? Should I avoid doing this in the future?
TIA for replies.
TIA for replies.
answers....
1. The shifter is adjustable. Chances are yours is not in alignment.
2. Ive had my V1 in the lighter for over a month and it works fine. So I guess its just an issue that your having since I havent heard of it before.
STFA, j/k. if the V1 works id say its just a faulty lighter. does it seem like it pops in right?
and if so if you hold it down for a bit does it get at all warm? As for the gate, it sounds like yours is off a bit. An easy fix
waples
S4 (B8 Platform) Discussion
09-03-2011 03:45 AM
BMWBig6
A4 (B8 Platform) Discussion
12
11-07-2008 02:42 AM
RubenS4
10-06-2006 05:54 PM
JPS
02-20-2000 05:06 PM
