finally found time to throw in my Hyperflow - ?? (Yes, I STFA)
I don't recall anyone specifically commenting on this but I assume its normal to hear a brief "Chhh" sound when you hit the gas? Almost like a mini blow off valve type of sound? I noticed it when I was reving the engine in the garage. I'll post more on my thoughts later but quick summary is:
-Noticable difference in throttle response (worth the $$ for this alone IMO)
-Car "feels" a little bit faster
-Sound with non-res cat back is mean
-Install was easy but having trouble getting the trim covers to fit perfectly (yes, I made sure the air box bumpers were removed). The CAD divider seems to sit a bit high which makes the covers sit a bit high.
Make sure that the heat shield is properly seated below, sometimes it wants to hang ...
when your installing it. Once flush with the bottom of the chassis, you should be good to go. But then again, you want to allow for a "seal" between the heat shield and the hood.
2000s4biturbo::Uli
17
01-18-2005 01:12 PM
maaliish
06-18-2004 07:12 AM
zszabo
11-02-2003 10:22 PM
rexism
01-17-2002 08:24 PM
