S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Help! Removing center cap on AVUS wheels
Old 12-09-2004, 03:11 PM
b2bisp's Avatar
Default Help! Removing center cap on AVUS wheels
How do I remove the AVUS center cap with the ring hook? The manual says: "with the hook pin engaged,..." What does that mean?
Sorry, it's my first Audi.
Old 12-09-2004, 03:12 PM
TXurS6's Avatar
Default Look in the trunk
Under the deck lid, left side of the tire. There is a wire ring in the black kit. Insert the end of the ring into the hole on the black ring of the cap. Pull the cap off.
Old 12-09-2004, 03:13 PM
AUDIS4BI:Vintage's Avatar
Default You have to tape your heals together three times while snaping your fingers above your head
lol I never used that 'hook' I just use to use a flat head screw driver.
Somesuch's Avatar
Default Just stick it in!
Insert the end of the pin into the hole.
Make sure you insert it far enough to "hook" the pin against the inside of the cap (the pin thingy is bent or curved, if I recall).
Then just pull -- it should pop off easily.
Old 12-09-2004, 03:14 PM
New Member
balloonknot's Avatar
Default Re: Help! Removing center cap on AVUS wheels
just pop it out w/a flathead.
Old 12-09-2004, 03:29 PM
b2bisp's Avatar
OK got it. I thought it was something more sophisticated than that.
Thanks!
S4Bloom's Avatar
Default The end of the hook should point inward....
...toward the center of the cap after you insert it. Then just pull sharply.
Old 12-09-2004, 08:17 PM
Junior Member
too good to be true's Avatar
can you do it without the wire ring?
Old 12-09-2004, 09:11 PM
Babyfoood!'s Avatar
It's my first Audi too, but I figured it out all by myself! I must be a genius or....
Old 12-09-2004, 09:34 PM
Member
davyk3's Avatar
GENIUS!!!
Quick Reply: Help! Removing center cap on AVUS wheels
