Lowering rear subframe question
I am nursing my way through this with little hands-on experience and a Bentley guide. Can somebody give me a bit more help? Support subframe with jack, loosen both bolts on each side (Big ones in the bushings, aiming down)..? Do I need to remove the sway bar? Do I need to pull the rear exhaust section? Will I still ne a spring compressor, or can I lower it enough to get the springs out? Not looking to bugger this up.
you are on the right track. Support the subgrame with a jack, take
out those big *** bolts, take off the plastic links for the traction control. You do not need to take off the sway bar or lower the exhaust. Lower the subframe slowly.
bpp
08-08-2006 01:07 PM
Installing my H-Sport on Saturday..Is it something a garage goon like me can do.Do I need jacks/lift
DesmoTesta
18
06-30-2006 11:36 AM
