S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Thoughts on recent RNS-E install...
Old Jan 21, 2009 | 08:10 PM
  #41
jba's Avatar
jba
Default just an anecdote - not even sure the brand of my antennae...
but i start out putting in my destination info in my manhattan garage (union square area) - and i always have 5 or 6 satellites before i see clear skies. I'm sure that the sharkfin would be even better, but the under-dash works great given how easy the install was. (two screws, some sticky tape and a pair of zip-ties.) I was paying very very close attention to not break or scratch anything and it still took less than 30 min..
Old Jan 22, 2009 | 09:43 AM
  #42
ClarkSJ's Avatar
Did you mount behind the cluster or some other location?
Old Jan 22, 2009 | 12:16 PM
  #43
ClarkSJ's Avatar
Default If the headlights cause you to lose signal you could try a few things
Like shielding the back of the RNS-E with foil, disconnecting one headlight and then the other to see if you can isolate the problem, moving the current antenna to another location, etc. If you turn the lights on during the day, so you lose signal? There should really be no difference in how you see the sats at night versus the day, unless there is some big difference in the atmopshere are night where you're located.
Seems like an odd problem. I think the antenna cable is a coaxial cable, so that is shielded and should not be prone to noise.
Old Jan 23, 2009 | 09:14 AM
  #44
jba's Avatar
jba
yes, behind the instrument cluster on the horizontal cross-brace.
Old Nov 1, 2012 | 11:53 AM
  #45
hersheyboy's Avatar
Default OEM SAT tuner location
Can anybody tell me where the OEM SAT tuner is located on my 2006 S4 with RNS-E and 6 CD glove box changer?
Old Nov 2, 2012 | 05:46 AM
  #46
hersheyboy's Avatar
thanks for your prompt response. Now I need to find the easiest way to get to the connections on the SAT tuner. I am planning to install a mediabridge adaptor.
hardipk5
17
Nov 24, 2015 03:42 AM
ITNETWIZ
TT (Mk2) Discussion
Oct 30, 2015 07:54 AM
Hadrian
2.0T FSI Discussion
Sep 16, 2015 10:59 AM
bagsformom
Q7 MK 1 Discussion
Sep 11, 2015 07:43 AM
Optimusglen
Sep 8, 2015 06:57 AM
