2010 S4 Trunk difficult to close
Before I ask the dealer to look at it I thought I'd ask if you guys have the same "issue".
The trunk on my 2010 S4 is very tricky. It seems to close fine, but unless you really slam it, I occasionally get the trunk is open signal inside the car. If this was a civic, I wouldn't bring it up.
Does anyone else notice abnormally hard force required to get the trunk open sensor to think the trunk is closed? Should I let the service rep know when I bring it in for 5000 mile service?
If I try and close it by pushing down on the left side it won't close. You must shut it from the middle. I will have mine checked at the 25k service.
anyway, at the OP, it sounds like a sensor issue.
Having the same issue myself. Unless I slam it, the trunk open indicator comes on, even though tugging on the trunk tells me it is closed. Plan on having them check it out at the 5k service.
Seems kind of dangerous for your hand.
you are not supposed to close it by pushing on the trunk at all. there is a small handle located on the inside of the trunk lid that you grab and pull down to close the trunk. found a quick pic from a B5: http://img.photobucket.com/albums/v1...e/738a6258.jpg
