S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Advanced Key option Q's
Old Oct 25, 2010 | 11:27 AM
kostas_os's Avatar
Default Advanced Key option Q's
A few questions to the S4 owners with the "Advanced Key" option. What happens if you leave the car with the engine running and walk away with the key in your pocket, does the engine shut off automatically at a certain distance? Can you lock the doors from the outside when the engine is running? Can someone drive away while you're standing outside with the key in your pocket?
Thanks in advance.
Old Oct 25, 2010 | 11:34 AM
JJsLegacy's Avatar
As far as I know the car will stay running and a little missing key symbol will be on the dash. Basically if you turn the car off you won't be able to turn it back on as no keyfob is around.
Technically someone could drive a way I suppose but they could just never turn it off
I haven't tried to lock the car from outside while running - I doubt that would work - can't test now or I would.
Old Oct 25, 2010 | 01:25 PM
NWS4Guy's Avatar
Also unsure about the lock, but you can definitely get out of the car with the key warning, it will still run till turned off, then it's not going anywhere without a key inside the car.
Old Oct 25, 2010 | 02:13 PM
Smith837's Avatar
You're not able to lock the doors once you get out (used to do that with my Infiniti)...and you're not able to unlock any locked doors either (e.g., the passenger door). Somewhat annoying at times, but I suppose it makes sense for added security.
Old Oct 25, 2010 | 02:15 PM
sworksone's Avatar
You can't lock the car with the key inside. The sensors detect if the key is inside or outside and locking is prevented if the key isn't inside. A cool trick to show people is to try to close the trunk with the key in it. The trunk won't even close, it's just pops back open again. I'm pretty sure you can drive the car if you leave it running with the key not in it, but haven't tried this personally.
Old Oct 25, 2010 | 04:32 PM
bscardin's Avatar
Default You can use the mechanical key
You can lock the doors if you use the mechanical key (i.e. slide the key out of the fob and in the door). If you do this you will also need to use the mechanical key to unlock the door. I have done this on road trips with our dog in the car when we stop to eat and it is hot outside. Good thing the car idles quietly
I remember I had an aftermarket car starter in high school that would automatically cut the engine when the brake was applied if the key was not in the ignition. Would be nice if the advanced key would do something like that.
Old Oct 26, 2010 | 03:47 AM
ranch's Avatar
It's been a while since I looked, but I thought the if the car doesn't find a key and is becomes stationary it won't let the parking brake turn off or the gear selector move out of park.
Old Oct 26, 2010 | 05:04 AM
drrick89's Avatar
Great for getting mail from those neighbohood island mail boxes which are about a block from the house.
beep-beep
24
Sep 23, 2023 10:04 PM
Cansv
Q5/SQ5 MKI (8R) Discussion
11
Jun 3, 2021 04:51 PM
Antonini
May 29, 2019 09:34 AM
samgauto
A6 (C7 Platform) Discussion
Feb 10, 2018 11:48 AM
Steve in VA
Jan 11, 2001 03:47 PM
