Backup Camera Option??? How did I do this?
I have had my car for about 2 months now and this has happened only once. I usually get the yellow guidance lines when I am reversing with the backup camera but the other day I swear there was an outline of a car on my display in the backup camera mode and I went into some menu that showed me the senors around the car and a picture of a car. How do I get back to that option? I did a VAG mod and is this part of the hidden menu options. I see no option for this in our user manual. WHAT THE HELL DID I DO? HOW DO I DO IT AGAIN?
I had the same issue with my 2010 Infiniti G37 sedan when I had it, the car came with rear parking sensors and camera, but the European version of the car comes with front parking sensors as well, so everytime I'd throw the shifter out of reverse, a diagram of the car shows up as if its supposed to show you the sensors for the car all around.
If I remember correctly, when you have the backup camera on, it's the upper right button from the center MMI dial to toggle between the two modes.
I haven't had a chance to look into how you're supposed to use the lines for parallel parking yet though...
Yep, one of the soft buttons on the MMI becomes the toggle, it has the name of the mode you are in on screen while the camera is active in the corner correlating to the button to push.
Parking mode 2: parallel parking
Parking mode 2, “parallel parking”, makes it easier for the driver to reverse park alongside the kerb. Two blue
fields are depicted - a light-blue field for reverse parking on the right-hand side and a dark-blue field for
reverse parking on the left. The static blue lines shown, indicate the ideal point at which the driver should
adjust the steering angle.
Procedure for reverse parking
If the dark-blue area fits between the two vehicles,
between which the driver intends to park, then the
space is large enough. Now reverse in a straight line
until the end of the dark-blue area touches the rear
of the vehicle (see the upper of the two
illustrations). Then reverse with the steering wheel
turned to left full lock. The driver must ensure that
he/she does not touch the vehicle he/she is parking
behind. When the dark-blue line touches the kerb
(see the lower of the two illustrations), the steering
wheel must be turned to right full lock and reversing
continued until the vehicle is parallel to the kerb.
The vehicle should then be driven forward slightly
and the vehicle will be parked perfectly.
