S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
DSG and a sudden increase in RPM
Old Nov 25, 2011 | 03:44 PM
evolvah's Avatar
Default DSG and a sudden increase in RPM
I have a 2011 S4 with DSG and about 6K miles on it. A couple of times I noticed a strange behavior from the transmission in Auto mode. I was cruising at around 65mph controlling the speed with the gas pedal (cruise control is off). Then, suddenly, the RPMs would jump from about 2K to 5-6K. At first, I thought I am being passed by a motorcycle because nothing in the car's behavior changed, and it was the increased engine noise that made me think of a motorcycle nearby. I did not feel any gear shift or anything like that. I was maintaining a steady speed.
Hitting on the right gear shift flap helped to solve the problem. It happened twice in two days and for the past week is was functioning as usual.
I'm curious if I should be concerned about the clutch slipping or a glitch in the TCU. I'm afraid that if I take it in to the dealer they will not be able to reproduce the problem. It would be different of this is some sort of a known problem, I think.
Regards,
/Sergey
Old Nov 25, 2011 | 04:43 PM
gmermel's Avatar
Originally Posted by evolvah
I was cruising at around 65mph controlling the speed with the gas pedal (cruise control is off). Then, suddenly, the RPMs would jump from about 2K to 5-6K...nothing in the car's behavior changed, and it was the increased engine noise .....I did not feel any gear shift or anything like that. I was maintaining a steady speed.
y
The irony.....
Your car downshifted several gears with no indication except the RPM change. I have no idea why, or what to do about it. But I sure am jealous. My DSG won't downshift without lurching and hesitating upon engagement. Really, though, I feel for you. It's irritating when these things don't behave themselves.....
Maybe we could get our cars together and breed them. The offspring might work perfectly?
Old Nov 26, 2011 | 04:13 AM
redrocker55's Avatar
Any fault codes?
Old Nov 26, 2011 | 06:47 PM
evolvah's Avatar
Originally Posted by gmermel
The irony.....
I am sorry to hear that you are having DSG problems. But I'm afraid that inbreeding has never been an answer to health issues!
evolvah's Avatar
Originally Posted by redrocker55
Any fault codes?
Would I be getting any fault codes if CEL is not on?
Old Nov 26, 2011 | 07:11 PM
helix139's Avatar
You could be. Run a scan in VCDS and post your log
Old Nov 27, 2011 | 02:21 PM
ilspazzaneve's Avatar
Kickdown switch on the throttle pedal is getting engaged, somehow. This would shift from 7th gear to 4th at exactly the RPMs you described.
Not a common problem, and unlikely to be activated by your foot or floor mat acidentally, but I'd take it to the dealer anyway.
zhang9211
Q7 MK 1 Discussion
11
Mar 25, 2016 12:28 PM
B7SLineCAT1212
A4 (B7 Platform) Discussion
25
Aug 23, 2005 10:36 PM
kahoTT
Apr 28, 2004 01:55 PM
WVTA4
Nov 4, 2003 12:10 PM
ScepTTor
Jun 18, 2002 07:52 PM
