possible clutch problem
Old Apr 28, 2004 | 01:21 PM
kahoTT's Avatar
New Member
Default possible clutch problem
Hi all, I just bought a used 2001 TT and I suspect that there's a problem with the clutch. One out of five times when i shift from 1st to 2nd gear, I will hear a loud grinding noise coming from the transmission, I can often duplicate this problem by:
1. drive pass 3000 rpm on 1st gear then shift into 2nd.
2. shift fairly quickly
This sound is gone right after i shift into gear but it is enough to give me a heartache that last a long time. Is this a known problem for Audi gear box? Thanks.
Old Apr 28, 2004 | 01:31 PM
SF_TTMT6's Avatar
Yes, try searching.
Old Apr 28, 2004 | 01:52 PM
bone sTTock's Avatar
New Member
Default sounds like syncros!
the "grinding" between shifts is usually a sign of your syncros going bad. How many miles on your car? is it a 225? coupe or roadster?
Old Apr 28, 2004 | 01:55 PM
rastispapps's Avatar
Junior Member
Default Drain your tranny fluid and...
replace with Redline MT-90. Sounds like metal shavings from break-in and bad shifts. That should do it. If it was the syncros it would happen at each shift in those gears.
RP
BrianInfo
Oct 10, 2009 05:52 PM
Racht
Audi R8
11
Jul 19, 2008 12:41 PM
rootkid
9
Mar 26, 2003 01:09 PM
FireOnIce
Nov 13, 2001 04:05 PM
Michael Richard
Jan 10, 2000 08:25 AM
