dynamic steering
There is a thread at Audizine on VAG-COM codes:
http://www.audizine.com/forum/showth...M-codes/page12
Someone figured out how to activate the system but from what I can tell the code they used DEactivated the servo steering. They describe having the steering effort at low speed to be so heavy that they end up turning off the dynamic steering.
OK you techies: Find out how we can activate dynamic steering while the servo steering remains active as well. Good luck.
go to 09-Cent. Elect.
go to Coding - 07 and change byte 7 from 01 to 00
You can read up on David's DIY at audienthusiasts.com but some of his coding is a bit different. Byte 8 is a bit confusing - pun intended. =)
Anyway, if you are familiar with VCDS, the following post should quickly help you enable ADS options including steering:
https://www.audiworld.com/forums/sho...&postcount=258
I'm wondering if you can clarify a bit more.
First off you mention "the function is not activated when you order the sports diff without ADS in North America the software for this function is in the car's computer." What do you mean? I thought with the sports diff you got the ADS-Lite package which includes the ADS control panel and the "dynamic" setting covered steering, throttle, gearbox(S-Tronic), and sports diff... and of course excludes variable ratio steering and suspension as they are only on full ADS equipped cars.
Second isn't this VCDS (VAG-COM) mod just basically disabling power steering assist. I mean in reality that is all the ADS-Lite "Steering" setting is doing anyway (varying the amount of power assist) but it sound as if he just shut it off altogether.
So the ratio function was activate but apparently the servo was disabled.
My question, then, is can you activate the servo independently so it still works when the dynamic steering is turned on
It has to be in there because the feature is available in Europe as a stand alone option with the sd.
I will post this in the vag-
Com forum too.....
http://www.youtube.com/watch?v=Ge7huVZANC4
On full ADS you get the variable power assist AND variable RATIO.
On ADS-Lite (i.e. sports diff only) you get just the variable power assist since the variable ratio hardware is not present. (I won't speak to the effects of the sports diff on the "steering" setting since I don't know them.)
What would be interesting would be if on say an A4 without full ADS you could enable the MMI screen for ADS-Lite effects for steering effort, throttle, tiptronic. Perhaps that is what they are referring to in the VCDS (VAG-COM) mods in the other threads?
