Max heating
Max heating
Question - in cold temperatures, whats the best way to heat up the car the quickest? Typically in previous cars, would crank it up to high and put on the air recycling until the car warms up. However, on the S4, I noticed that when I hit the recycle button, the AC button also comes on. Should I turn the AC off, or leave it alone?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
If you have it on recycle with the AC off, you will turn your car into a steam bath and it will fog up for sure. The AC removes moisture from the air and therefore keeps the humidity down and the windows clear. I find the Auto setting with A/C off works very well here in Vancouver. No fogging at all. Depending on your climate, you may need the A/C on to keep the windows clear.
Banned
Turn the AC OFF. There is no reason to run the AC compressor if you don't need to cool the car. It will cause you to use more fuel and acomplishes nothing. BTW, I have been amazed at how quickly the engine warms up and blows hot air out of the heating ducts.
I agree with the good Doctor. Auto mode annoyed me as it kept putting the AC 'on' even in winter. I run in manual mode and adjust the air flow and temp as needed. If I kick the front defrost on, the AC does kick on until I shut it off. No complaints from me on the heat/system otherwise.
The best way to warm up your car is start it, put on your seatbelt and drive gingerly until the car is warmed up. Once it is at operating temperature drive her hard. Idling a car is a waste of fuel. Sitting there your car is getting 0 mpg. It is also hard on the catalytic converter. The air conditioner comes on to correctly maintain the humidity levels in all seasons. The only time I allow my car to sit running is the time it takes to scrape the snow/ice of my windshield and windows. Hope that helps.
There's no Automatic "Economy" mode? My '02 Maxima had that. It would still operate automatically (fan speed, temp, & outlets), but not run the A/C compressor.
Banned
No. I use Auto 95% of the time and have just become accustomed to hitting the Auto button and then the A/C button to shut it off. Another Audi quirk like maps, radio presets, and mix mode.
