S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Overheating issue
Old 06-23-2018, 06:02 AM
das84's Avatar
Default Overheating issue
Hi everyone,
I'm having an issue with my 2012 S4 (64K miles) and I'm at my wit's end about it. After driving the car for a while (or when it gets to operating temperature), if I stop for a few minutes like when in traffic or when I park, the engine fans turn on at high speed and the temp needle on the cluster rises above the halfway point--but doesn't reach the 3/4 mark--for about 15 seconds, then goes back to normal.Back in December, my water pump went out and my mechanic not only changed that, but also changed the thermostat. This time around, they had the car for about 3 weeks and have changed the thermostat two more times, the water pump again, the radiator, various hoses, and bled the system ad nauseam. Still, the problem persists. It's also not losing any coolant. My mechanic also told me that when it overheats, it seems as though the coolant isn't flowing smoothly, but after changing all those parts, they have no idea where the blockage could be. Has anyone ever had this problem or have any idea what additional steps to take to troubleshoot and/or fix it?Some potentially relevant info: the car has a Revo stage 2 tune and an ECS Tuning intake. But those have been on for a while before it started doing this.
Thank you for your help
Old 06-23-2018, 11:14 AM
das84's Avatar
Originally Posted by DrGP
Normally, I would think it was caused by the T stat. But since you have changed it more than once, perhaps it is the coolant temperature sensor?.
Thanks for your reply. I forgot to mention that I get no warning lights or anything on the cluster. Do you still think the sensor could be faulty?
Old 06-23-2018, 03:36 PM
das84's Avatar
I really don't have enough expertise on this subject to give you a valid answer. Just throwing out a possibility that I have previously read about on the forums relating to this. But if you really want some more knowledgeable responses, .post this on Audizine B8 S4 forum.
Will do. Thank you again.
TDIII
14
10-07-2013 11:53 AM
MonkeyMadness
10-30-2007 06:45 AM
eCoastAudi
12v V6 Discussion
02-07-2007 08:04 PM
halflife
11-13-2004 09:03 AM
anonymouslychipped
03-05-2003 10:20 AM
Quick Reply: Overheating issue
